91 Accord AC clutch prob
Old Jul 22, 2013 | 11:29 AM
tinkerer123's Avatar
Default 91 Accord AC clutch prob
Had to replace my AC compressor because it leaked all the refrigerant (it was converted to 134a about 8 years ago). I also replaced the dryer, drew down vacuum and let it sit for a couple of hours with no leaks. I added 5 oz of PAG oil when I installed the compressor and I added 30 oz of refrigerant. The clutch would not engage so I jumped it to get the charge in and I had cold air in the cabin. When I reconnected the wire and pushed the AC switch, the idle comes up and the fans come on, but no clutch. With it jumped out, I was reading 55 on the low side and 130 on the high side. Ambient is 80 degrees. Any troubleshooting ideas before I have to bring it to the local shop? I would prefer to eliminate everything first because I don't trust the local AC shop (long story). Thanks
Old Jul 24, 2013 | 02:11 PM
Lost Again's Avatar
Default Re: 91 Accord AC clutch prob
Can you test the inputs to the ac compressor relay?
Old Jul 24, 2013 | 04:00 PM
jdm92_accorn's Avatar
Its probably a pressure switch. I don't remember if the high pressure and low pressure switche's are separate or not on the cb's.
Old Jul 29, 2013 | 07:32 AM
Hey guys, thanks for the input, I replaced the compressor relay and it's working fine.
hall97civic
Jan 3, 2015 12:17 PM
CG01
Engine Management and Tuning
Nov 7, 2012 08:18 PM
mac_24_seven
Mar 6, 2006 01:19 PM
adan CRX
Nov 26, 2003 08:41 AM
