92 accord fuel pump shuts off
Old Jul 21, 2013 | 05:55 PM
Dobird78's Avatar
Default 92 accord fuel pump shuts off
my 92 accord fuel pump shuts off in the heat after about 30 min. has new main relay ignition coil, cap and rotor. will not start for about 45 min and then I get about 5-10 min out of it after. anyone else have this problem. also I noticed my tach spazing out for a short time, only once.
Old Jul 21, 2013 | 06:01 PM
DeadlockRiff's Avatar
Default Re: 92 accord fuel pump shuts off
Have you already checked the ground wire and wires that run along the same subharness for possible backfeeding?
Old Jul 21, 2013 | 06:29 PM
Dobird78's Avatar
Have not. how would I check for backfeeding, wouldn't a bad ground cause this all the time. I don't seem to have this problem on my way to work when it is cool in the mornings.
Old Jul 21, 2013 | 06:38 PM
a bad ground can heat up due to resistance and then as it heats up add additional resistance until the electricity can no longer flow. This going with the fact it happens in the heat.
For the backfeeding just check for any wires that are both open an contacting each other.
EDIT:
Try adding a redundant ground that runs to a different location and see if that solves your problem.
Old Jul 21, 2013 | 10:14 PM
holmesnmanny's Avatar
The tach is given it's signal from the ignitor. I would swap that out with one from the junkyard and see if that fixes it. Your existing ignitor could be overheating. They have a heatsink on them but perhaps yours isn't working right.
dman67
Jan 19, 2015 03:02 PM
James Olmstead
May 21, 2012 07:26 PM
camaroprelude
Dec 13, 2006 04:30 PM
JBMINI
Jul 15, 2006 05:20 AM
Accord1980
Jan 29, 2003 01:28 PM
