Acura tl 2000
I had timing and water pump failure bent valves. Took it down replace
Water Pump and timing belt head reconditioned wit new valves. Had
Valves ajusted and also Install
New knock sensor put it all back car runs but idle low and high I changed
The idle control valve and it now idle steady but engine vibrates and sluggish
when accelerated I change plugs and coils still the same. I got engine chk lite
And got diagnostic code p0325 could some one help me please
rough idle problem, just started tonight, here's what i did, someone pls tell me what else i can try
SYN4DRDX
Oct 23, 2005 08:44 AM
