Parting Out JDM Front CRX plus a ton of other good parts NEED GONE NOW.
Highend First Edition Tri Y B Series Header with Donut Gasket $225
AEM B Series Fuel Rail was sandblasted so I can powdercoat never did it $45
Innovative H Series in EF Chassis Mounts missing weld in bracket has actuator $225
Tial 2 bolt 38MM Wastegate $150
Innovative Wideband no sensor $90
B AND M Short Shifter with Pivot Ball mount $100
EG Headlights with HIDS $50
B Series VTEC Valve Covers $85 each Pink One $125
3 Inch Flex Pipes $35 each 12 inch long
B18c1 gsr block fresh from rs machine 82mm bore honed and decked with manley gsr rods and wiseco high compression pistons. NO CRANK NO RINGS NO BEARINGS. $900
Adding more parts and pics will be up shortly.
Chuck
310-977-1201
Mounts
Header
VC
INTAKES
SHIFTER
FLEXPIPES
MISC
GSR Block, Pistons, Rods:
Chuck
310-977-1201
Mounts
Header
VC
INTAKES
SHIFTER
FLEXPIPES
MISC
