Honda CR-V & Element 2WD & 4WD Element & CR-V
AC compressor Viscosity and Charge
Old Jul 19, 2013 | 07:39 PM
NIKADEM0's Avatar
Default AC compressor Viscosity and Charge
I had a hole in my AC suction hose. I replaced the hose and I am ready to recharge my AC. I'm assuming I lost oil the system needs but I am not sure how much or what kind to get. Below are what my options are. I have to get my AC working ASAP because I am going on a road trip to the Florida and well, it's gonna be HOT!! I have more options for the R-134a if I need more. These cans have 1 oz oil, 1 oz R134a and 1 oz sealer stuff. . . Please help before I melt to death!
Old Jul 22, 2013 | 10:54 AM
microcraft's Avatar
Default Re: AC compressor Viscosity and Charge
Do you have a vacuum pump? You will need to pull a vacuum to remove the air and moisture in your system from when you had the system open and exposed to the environment to replace the hose.
Then it gets a bit complicated. You should clean & flush the system so that you are starting from scratch so you know how much oil & freon to add. Course you could just chance it, pull a vacuum and dump the correct amount of freon in.
-mc-
Old Jul 22, 2013 | 10:59 AM
NIKADEM0's Avatar
-mc-
I figure most of the oil sprayed out when the hole opened up since its under a good amount of pressure. I ended up using 4 cans of the 3 oz (1oz oil 1 oz r134a 1 oz sealer) and two 12 oz cans of pure r134a. The pressure gauge said it was still good. Ac works fine, not super super cold but cold enough to cool off. Hopefully it'll make it through my road trip. I honestly don't even like using it. I can feel it bog down my B20!
flanker
39
Mar 25, 2015 08:56 PM
curtie94
Apr 8, 2012 05:05 PM
Kid_SiR
May 7, 2011 09:47 PM
Ldo
Aug 10, 2008 05:08 PM
LoneStarCRX
13
Apr 18, 2006 08:10 AM
