clutch replacement
Old Jul 19, 2013 | 07:23 PM
lfdelar2's Avatar
Default clutch replacement
i have a manual 96 honda accord 4 cyl stock. I have had it about a year now. I am noticing that its lacking power. I dont feel the force that it had. Idle is fine no code or anything but i still feel that the car is lacking power. I learned to drive standard on the car and am beginning to think that i might of burned the clutch on it. I have no idea when they replaced the clutch. DO i need a clutch and if so which is the better brand? Its my daily driver so i dnt want to put but stock parts in there for now
Old Jul 19, 2013 | 07:36 PM
Mishako129's Avatar
Default Re: clutch replacement
I would not replace the clutch if it doesn't need it, it sounds like your engine is the problem not your clutch. I would start by doing a compression test and find out the health of your engine. A new clutch will not benefit your power unless you have something much more than stock like a camshaft, turbo, or a tuned ECU.
Old Jul 19, 2013 | 08:27 PM
NZXTInerTia's Avatar
If the clutch is worn out the disc will constantly slip reducing power.
Old Jul 19, 2013 | 10:22 PM
holmesnmanny's Avatar
It doesn't sound like you need a clutch, but if you really want to replace your clutch, then just replace it for no reason.
Ash J. Williams
Transmission & Drivetrain
11
Nov 13, 2012 09:03 AM
Minirex61
Honda Civic (2001 - 2005)
Mar 20, 2007 07:39 PM
DANgerous
Apr 4, 2004 01:37 PM
SilverS
Feb 26, 2002 02:21 PM
