d15b7 ticking
Old Jul 19, 2013 | 03:02 AM
ef_si's Avatar
Icon4 d15b7 ticking
can anyone help me ? my engine in my hatch is making like a ticking/clicking noise not while idled there but while im driving at a certain rmp (cant tell what rmp cuz my rmp gauge doesnt work) itll make that noise . can anyone help me out or have any ideas? thanks i really appreciate it
Old Jul 19, 2013 | 03:41 AM
JuggerNaut-CTR's Avatar
Default Re: d15b7 ticking
Have you looked around the engine bay and even listened to see if you can hear where its coming from?
Ear close to the valvetrain?
Listening by the accessory belts?
Only a few places a ticking can come from....
Old Jul 19, 2013 | 04:19 AM
Tim512001's Avatar
What rpm range? Medium like normal driving or high like before shift or gettin on it? Could be oil thickness issue but my guess would be valves need adjustment.
Posted from Honda-tech.com App for Android
Old Jul 19, 2013 | 01:03 PM
ef_si's Avatar
it sounds like under the valve cover as i listened and it does it as im driving normal before shifting once i shift it quiets down then at a certain rmp it does it again
Old Jul 19, 2013 | 01:06 PM
Former User's Avatar
Could be bad gas, or the ignition timing or valve clearance needs adjustment.
What car?
Old Jul 19, 2013 | 01:10 PM
ef_si's Avatar
i can try that and its in my 91 ef si hatch
Old Jul 19, 2013 | 01:12 PM
What ECU?
Old Jul 19, 2013 | 01:14 PM
ef_si's Avatar
to be honest i am not to sure
Old Jul 19, 2013 | 01:16 PM
Find out. There will be a label on it. Should be a P06.
Any CEL codes?
Old Jul 19, 2013 | 01:24 PM
ef_si's Avatar
were would it be located and how can you tell about cel codes ?
Old Jul 19, 2013 | 01:25 PM
The stock ECU for your car would be located under the front passenger's carpet. Look there first.
The method for checking CEL codes depends on what ECU you have.
Old Jul 19, 2013 | 01:31 PM
ef_si's Avatar
my ecu is a pm6
Old Jul 19, 2013 | 01:36 PM
The PM6 ECU is OBD0 and is for the D16a6 engine (I think). The D15b7 engine is OBD1 and requires the OBD1 P06 ECU.
My guess would be that the engine-ECU mismatch is the root cause of your problem. There may be other problems, but first address this important one.
Old Jul 19, 2013 | 01:47 PM
ef_si's Avatar
you think that would cause what its doing ?
Old Jul 19, 2013 | 02:11 PM
It's very possible. Maybe others will also chime in.
There's a Codes sticky at the top of this forum. It'll tell you how to look for codes on your PM6.
Old Jul 19, 2013 | 02:19 PM
ef_si's Avatar
alright bro thanks i will get that ecu and see whas up
Old Jul 19, 2013 | 05:46 PM
crvtectim's Avatar
You should verify the mechanical timing is spot on as well. A tooth off could cause some chatter like you've described.
Old Jul 22, 2013 | 03:09 PM
turn&burn89's Avatar
so the On-Board Diagnostics is mostly for emissions but various other sensors like the TPS, knock sensor, crank position, cam postion etc...they send electrical currents to the ecu. they are mostly electrical sensors not mechanical, especially OBD0 and OBD1. for noises you hear, you usually have to diagnose yourself. so start w/ the valve adjustment and oil change. its the infamous single cam tick, every one ive owned had the same thing until i did the adjustment and a good rule of thumb is ''you'd rather hear it, then smell it.'' (the gas you waste from making them too tight.)
sector001
Oct 13, 2006 12:09 PM
MODsjtown
Jan 4, 2005 01:05 PM
MrEg
Oct 13, 2003 04:47 PM
bananacruzier
Feb 16, 2002 10:06 AM
BryanS
Sep 25, 2001 10:46 AM
