Passenger seat occupancy bypass
Is there a module or bypass/fix that tricks the car into thinking there is always a passenger in the seat?
Asking as I'm looking to replace stock seats with Recaros.
The ABS 2ohm resistor bypass isn't an issue, but what have people done about the weight sensor?
Thanks guys!
Thanks guys!
Yes, I also want to know what can be done with this weight sensor.
I try to look at Parts Catalog (in my case Honda Fit 2013),
and I could not find the part number for this weight sensor on the passenger seat.
I guess it must be integrated into the seat rail or something...
taking a stab in the dark, look under the seats and check if you see a connector with 2 wires on it, if you do, just the 2 wires on the connector coming out of the carpet.
I am assuming it has manual seats
PurpleB20B
Nov 7, 2008 12:17 AM
