01 Honda Accord Ex 2.3L Transmission Help
Old Jul 18, 2013 | 09:48 AM
Scottelaxe's Avatar
Default 01 Honda Accord Ex 2.3L Transmission Help
My 2001 Honda Accord broke down about a year ago because the transmission blew. I finally got a new used 01 Honda Accord Ex 2.3L V-tec transmission, which costed 1200 bucks with shipping and has 30k miles. While unloading it the people had the pallet it was on brake on one side and fall about 3 foot and hit the ground. The only pieces broken as far as I can see are the clutch valve and another valve on the top. I figured before I go get it fixed and put into my car, I would ask for some help to see if any other pieces need replacing. Valves run 50-100 buck so it isn't that bad. Should I let the person that is going to install it in my car rebuilt any pieces broken? Kinda up in the air about what to do. I am posting plenty of pictures so any other advice would be great, thanks.
Old Jul 20, 2013 | 01:45 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 01 Honda Accord Ex 2.3L Transmission Help
Those pictures are HUGE!
But it looks like the tops of the shift solenoids were popped off, usually you can pull these off to clean the pintle valve and screens if they get gummed up.
See if you can pull the caps off and just remove the solenoid section from the vale seat/base plate. If so and the pintle vales are not damaged you may be able to pop them back on and they should work.
mkfrl
May 8, 2019 04:36 PM
Jut4141
Northeast (Sales)
Oct 3, 2009 07:51 AM
jennifer28
Nov 29, 2007 07:25 PM
