ecu swap require a flash?
Old Jul 18, 2013 | 08:12 AM
smeags's Avatar
Default ecu swap require a flash?
I have a 00 civic dx where a 96 d16y8 motor and transmission have been swapped in. the wiring harness was switched to obd2b and ecu switched to a p292 -a92. the cel is now on for sall the vtec sensors. Is there a flash or tune required when swapping ecus?
Old Jul 18, 2013 | 08:13 AM
slomofo's Avatar
GDD Member
Default Re: ecu swap require a flash?
No.
Old Jul 18, 2013 | 08:22 AM
grumblemarc's Avatar
The Grumpiest
The ECU is a what?
OBD2 cannot be altered.
Old Jul 18, 2013 | 08:40 AM
smeags's Avatar
ecu is a p2pa92...
Old Jul 18, 2013 | 08:42 AM
smeags's Avatar
but why would all the vtec codes be showing up? I cleared the cel and it just comes right back on. What else would cause this?
The Grumpiest
And you're not running an adapter harness? OBD2A to OBD2B?
Old Jul 18, 2013 | 08:47 AM
Fliptard's Avatar
in order for it to work, you need to switch the engine harness, *** well as the cabin harness, plus a dash and all that goes with it from a 99-00 civic excluding HX model. 96-98 (obd2a) and 99-00 (obd2b) are completely different wiring.
Old Jul 18, 2013 | 09:15 AM
smeags's Avatar
obd2b works in p2pa92 ecu I looked all this up. Why would the cabin harness need to be changed?
Old Jul 18, 2013 | 09:19 AM
smeags's Avatar
I already swapped the engine harness to obd2b. shouldn't it be plug and play with the cabin harness no matter which one for 96-00?
Old Jul 18, 2013 | 09:33 AM
slomofo's Avatar
GDD Member
You guys aren't understanding what the OP's setup is.
He has an OBD2B car
He swapped an OBD2A engine into it.
He is using an OBD2B harness on the engine.
He is using an OBD2B ECU with this engine.
His car is already OBD2B and he's using an OBD2B ECU, there are no changes needed.
Here's the kicker.... His car is a DX and the new engine is from an EX with VTEC. His new ECU is also from an EX which has VTEC and now he's throwing codes for all the VTEC components.
Obvious answer: He needs to wire up VTEC.
Old Jul 18, 2013 | 09:36 AM
smeags's Avatar
yes the above is all correct but it has vtec wiring on the harness...
Old Jul 18, 2013 | 09:37 AM
The Grumpiest
He has an OBD2B car
Good job in clearing that up.
Old Jul 18, 2013 | 09:40 AM
kyden's Avatar
what harness are you using? ex or dx?
if using ex.. I would verify oil pressure.
Old Jul 18, 2013 | 10:17 AM
smeags's Avatar
ex... verify oil pressure?
Old Jul 18, 2013 | 10:19 AM
Fliptard's Avatar
my bad, I read wrong. Grab an EX or SI engine harness and you should be good to go.
Old Jul 18, 2013 | 10:25 AM
smeags's Avatar
I have an ex engine harness on the vehicle!
Old Jul 18, 2013 | 10:28 AM
angrysmileyface's Avatar
Im gonna throw a guess on this, but Im betting the OP needs to add the wiring that goes from engine harness to cabin/ecu harness for VTEC.
Old Jul 18, 2013 | 10:30 AM
kyden's Avatar
he doesn't have to, an ex harness already has vtec.
Old Jul 18, 2013 | 10:48 AM
even at the shock tower to the ecu?
Old Jul 18, 2013 | 11:02 AM
Shmallow's Avatar
That connection is on 92-95 civics. a 2000 model year (all 96-00) has one continuous harness to the ecu.
Old Jul 18, 2013 | 11:55 AM
smeags's Avatar
any other ideas for why it's throwing codes?
Old Jul 18, 2013 | 12:29 PM
kyden's Avatar
low oil pressure, bad wiring, bad solenoid.
Old Jul 18, 2013 | 02:37 PM
smeags's Avatar
Ok cleared it again and only knock sensor and o2 sensor are showing up. I replace the knock sensor already because it was broken and noticed it during the wiring harness swap. also now the vehicle seems to accelerate by itself up to like 40 after driving it for a while and getting it to operating temperature
Old Jul 18, 2013 | 03:22 PM
Marvin1985's Avatar
Post the codes you are getting. Make sure all plugs are Firmly connected to the Correct locations.
Old Jul 18, 2013 | 03:32 PM
smeags's Avatar
codes are for the knock sensor and o2 sensor. all plugs are in firmly.
