need info!Civic88 swap Integra91
Old Jul 17, 2013 | 11:59 PM
entoy's Avatar
Default need info!Civic88 swap Integra91
hi,those anyone can help me and more info!i have my Civic 1988 DX hatchback swap Integra 1991(non-vtec)i need some information about the wiring harness from motor to ECU.basicly,in the process the engine bay and performing a wire tuck.i have run into a couple of problems,and need some help you guys.
Thanks and advance.
Old Jul 18, 2013 | 12:47 AM
Top shotta's Avatar
Default Re: need some help pls!!!
U have to convert your dpfi to mpfi and then you need to run two wires from the ecu harness to the dizzy.
Old Jul 18, 2013 | 01:28 AM
entoy's Avatar
ok,so from ecu wire?which two wire i should run to dizzy?
thanks...
Old Jul 18, 2013 | 02:11 AM
CO671's Avatar
Default Re: need info!Civic88 swap Integra91
What is your question? You stated the situation but not the concern.
Old Jul 18, 2013 | 02:17 AM
entoy's Avatar
my question is?i have a civic 1988 DX hatchback swap to Integra 1991(non-vtec)
i need a wiring harness from the motor bay to ECU? I use ECU PM6.
those guys any info?i appreciated.
KraziCivicSi
Nov 9, 2006 11:35 AM
efhatchbackracer
Oct 21, 2005 12:18 AM
infamousALLMTR
Dec 8, 2002 02:02 PM
