ECU Pins
Old Jul 17, 2013 | 05:30 PM
Freemananana's Avatar
Default ECU Pins
Doing a b series swap into an EF (1989 HB) and my ECU is lacking pins. I totally forgot about this. Are all the ECU connections the same size? As in, A and B/C areas of the ECU being the same pins. And where can I get extra pins so I can connect my wires to the ECU?
Photos:
I am not sure if these are the same size. And I don't know where to get pins. Can I get them at like Radio Shack or a computer store? Maybe auto zone has them?
ALSO! Important.
Some of the MPFI swaps and B series wiring says to connect, say for example, Vtec solenoid to A8. There is already a wire there. What do I do with that wire? Just leave it hanging? Connected to nothing?
Thanks a lot.
Old Jul 20, 2013 | 03:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: ECU Pins
A plugs are different than B and C. Junkyard will have them. If a pin is in a location either depin or you can use that wire to hook up VTEC or whatever sensor.
Freemananana
Jul 25, 2013 07:27 PM
Hegster
Mar 20, 2007 12:04 AM
untitledsn41
Aug 5, 2004 07:51 PM
