replaced wheel bearing 99 em1 now more noises
Old Jul 17, 2013 | 02:35 PM
carbon fiber coupe's Avatar
Default replaced wheel bearing 99 em1 now more noises
had a wheel bearing going out so I replaced it....
now I am getting a "scratching" noise from the front?
Also now in the rear I am hearing a "hummmming" sound could it be noisey tires? maybe I can post a video
I don't think the rear is a wheel bearing
Old Jul 17, 2013 | 03:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: replaced wheel bearing 99 em1 now more noises
Did you use OEM bearings?
Old Jul 17, 2013 | 05:09 PM
dafreeeze's Avatar
Could be shitty aftermarket wheel bearings. Spend the extra money its worth it
Old Jul 17, 2013 | 06:37 PM
redyute's Avatar
For the rear humming noise,rotate the tires to see if the noise moves to the front,happened to me i changed the wheel bearing only to find out it was a bad tire, for the scratching noise make sure the backing plate is not rubbing against the rotor.
Phil_46
Jun 11, 2013 09:16 PM
ShinyNewPenny
13
May 28, 2009 06:30 PM
Mr_Moos
Jul 10, 2006 02:50 PM
GReddy212
Sep 14, 2005 09:25 AM
jdmstreethatch
Aug 7, 2004 01:40 PM
