2002 Honda S2000 Parts car
Car # Year Make & Model Version Engine Size Transmission
13042 2002 Honda S2000 2 Door 2.0L 6 Speed - Manual
http://www.ahparts.com for more details - email info at ahparts dot com or call 877-859-0023
Item # Part Price
63616 F BUMPER REINFORCEMENT 71130-S2A-000 $105
63617 RADIATOR SUPPORT / BULKHEAD $99
63618 RH HEAD LIGHT complete with HID $550
63619 LH HEAD LIGHT complete with HID $550
63620 HOOD 60100-S2A-A91ZZ $275
63621 RH DOOR LOCK ACTUATOR 72110-S82-G01 $50
63622 LH DOOR LOCK ACTUATOR 72150-S82-A01 $50
63623 MASTER WINDOW SWITCH 35750-S2A-A02 $50
63624 LH DRIVER OUTSIDE HANDLE blue $35
63625 RH PASSENGER OUTSIDE HANDLE blue $35
63626 2DR LH DOOR PANEL CMPLET -SWITCH $175
63627 2DR RH DOOR PANEL CMPLET blue $175
63628 2DR RH WINDOW REGULATOR $99
63629 2DR LH WINDOW REgulator $99
63630 LH MIRROR blue $75
63632 FUEL PUMP $60
63633 FUEL TANK $69
63634 FR/R SEAT blue $499
63635 FR/L SEAT blue $499
63636 FR/L BELT dark gray 04818-S2A-A04ZA $150
63637 FR/R BELT dark gray 04814-S2A-A03ZA $150
63638 STEERING COLUMN $95
63639 DASHBOARD,blue $150
63640 AM/FM/CD RADIO looks new $200
63641 DRIVER WHEEL AIRBAG black $199
63642 RH DASH AIRBAG blue $175
63643 SPEEDOMETER CLUSTER,MILEAGE=66k $299
63644 STEERING WHEEL 78501-S2A-A71ZA $150
63645 HEAD LIGHT SWITCH $25
63646 WIPER SWITCH $29
63647 RH SUN VISOR,black good $30
63648 LH SUN VISOR,black nice $30
63649 MT IGNITION SWITCH + KEY $75
63650 FR/L DOOR GLASS $70
63651 HEATER/AC CONTROL(ON DASH) $50
63652 ENGINE,MILES=66k,WARRANTY=6mo $2850
63653 MT TRANS,MILES=66k,WARRANTY=6mo $550
63654 HARMONIC BALANCER $65
63656 RR / RH AXLE $100
63657 RR / LH AXLE $99
63658 FRONT SUB FRAME $150
63659 FR/R UPPER ARM check $0
63660 FR/L UPPER ARM $75
63661 FR/R LOWER ARM check $0
63664 FR/L LOWER ARM $125
63665 RR/R UPPER ARM $125
63666 RR/L UPPER ARM $125
63667 RR/R LOWER ARM $40
63668 RR/L LOWER ARM $40
63669 FR/R STRUT N SPRING check $0
63670 FR/L STRUT N SPRING $75
63671 RR/R STRUT N SPRING $80
63672 RR/L STRUT N SPRING $80
63673 FR/R SPINDLE KNUCKLE check $0
63674 FR/L SPINDLE KNUCKLE $150
63675 FR/R BRAKE CALIPER $60
63676 FR/L BRAKE CALIPER $60
63677 RR/R BRAKE CALIPER $39
63678 RR/L BRAKE CALIPER $39
63679 RR/R SPINDLE KNUCKLE $125
63680 RR/L SPINDLE KNUCKLE $125
63681 ABS/VSA PUMP/MODULATOR $85
63682 RACK AND PINION $215
63683 ECU ENGINE CONTROL MODULE $150
63684 AIRBAG COMPUTER $85
63685 ROOF COMP $65
63686 EPS POWER STEERING COMPUTER $125
63687 ALTERNATOR $75
63688 STARTER $65
63689 ENGINE HARNESS,MT 32110-PCX-A02 $250
63690 BLOWER MOTOR $100
63691 AC FAN ASSEMBLY $75
63692 RADIATOR FAN ASSEMBLY $75
63693 4CYL RADIATOR $120
63694 AC CONDENSER $60
63695 AC COMPRESSOR $99
63696 AIR CLEANER SETUP $100
63697 RADIATOR OVERFLOW TANK 19101-PCX-000 $15
63698 EXHAUST MANIFOLD $150
63699 INTAKE MANIFOLD $125
63700 MT THROTTLE BODY $150
63701 LH CARPET, BLUE 83352-S2A-A03ZC $99
63702 RH CARPET, BLUE 83302-S2A-A02ZC $99
63703 FR/L RIM, nice 5 spoke 16" $100
63704 FR/R RIM, all around scratches $55
63705 RR/L RIM, good 5 spoke 16",few faint $90
63706 RR/R RIM, minor scratches, some curb $80
ahparts
Jul 23, 2013 06:08 PM
