A/C Warm Air Clutch moves with resistance
Old Jul 17, 2013 | 11:08 AM
lankan-balla's Avatar
Default A/C Warm Air Clutch moves with resistance
Hey all a month or 2 ago i had put in new refrigerant and my a/c was working then more recently only warm air is blowing. I went to check the pressure and it was on Warning (before it was reading the appropriate blue area when new refrigerant was put in) so im assuming there is no leak?
Also I began moving the clutch on the compressor wiith my hand and it keeps turning with some resistance so the compressor should be good.
Any ideas?
Old Jul 17, 2013 | 12:23 PM
lazlong's Avatar
Default Re: A/C Warm Air Clutch moves with resistance
If it's on warning now and wasn't before then you have a leak. The most common place is where the lines meet the compressor although the only way to really find the leak is with dye specifically made for A/C systems.
josh devera
Dec 25, 2016 10:27 AM
yoblocher
Jun 28, 2016 08:33 PM
saveacivic
Jun 24, 2008 09:21 PM
DSayavan
Aug 31, 2003 09:14 PM
Old91CivicGuy
Apr 20, 2002 03:37 PM
