Crazy CEL Issue
Old Jul 16, 2013 | 07:26 PM
94civiccpe's Avatar
Default Crazy CEL Issue
Ok first off before I begin I have searched tons of threads on this site and others... Still have not found what is causing this.
95 civic sedan turn the key on dash lights all light up CEL stays on can't hear the fuel pump prime like it should wont start. Leave the key in the ON position and wait between 10-25 minutes youll hear the fuel pump prime and the CEL will go off and the car will start and run fine.
So the first thing I did was try to pull codes well it comes back as code 0=fried ECU? So ive tried several diff ECUS and still the same issue. Ive also replaced the main relay 3 or 4 times still having this issue. Checked all fuses and grounds still the same issue! Its driving me nuts please does some body have any idea to what the hell is going on?
Old Jul 16, 2013 | 07:36 PM
killa_bee07's Avatar
Default Re: Crazy CEL Issue
It sounds like your main relay is going out.
Old Jul 16, 2013 | 07:41 PM
94civiccpe's Avatar
replaced it a few times.. along with the ECU
Old Jul 16, 2013 | 08:06 PM
94civiccpe's Avatar
Heres one thing I may have missed.. any one think it may be the ignition switch?
Old Jul 17, 2013 | 02:16 PM
94civiccpe's Avatar
any ideas?
Old Jul 17, 2013 | 02:20 PM
grumblemarc's Avatar
The Grumpiest
Check that no leads have been pushed out of the ECU plugs. That's all I got.
Old Jul 17, 2013 | 03:47 PM
knoxrocks222's Avatar
Bust out the multi meter man!!! Start at the fuel pump have someone turn the key if no current move to the next thing back and so on untill you find current
Old Jul 17, 2013 | 04:15 PM
94civiccpe's Avatar
thats the thing it shuts down the whole car no spark or fuel.... I get power to the fuel pump... but it still wont start because of no spark.. that light goes off the system primes and every thing works like it should.
Old Jul 17, 2013 | 04:50 PM
94civiccpe's Avatar
ive been told leaky capacitors in the ECU but I have switched it out time and time again... Bout to try a new dash harness and see if that is the problem
Old Jul 18, 2013 | 07:48 PM
I had a similar problem and it was the ignition. Change your ignition out. Only thing is your gonna have to keys unless you get it from the dealer with the vin.
fog raw
15
Nov 8, 2011 09:58 AM
stunn'd
Jul 11, 2008 06:37 PM
eg6d15
Apr 22, 2008 01:05 PM
hotinteggy
Oct 22, 2007 04:44 PM
blackeg
Apr 3, 2007 07:07 AM
