Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
02 MDX blower stopped working in the front
Old Jul 16, 2013 | 04:39 PM
95blackLS's Avatar
Default 02 MDX blower stopped working in the front
My wife's car has never had any problems. Randomly tonight right before leaving our house the MDX was running at idle, a/c blowing perfectly. All of a sudden the front stopped working, and the back was still working. Nothing changed on the control panel. Tried changing the fan speed, turn it on and off, shut the car off and didn't change anything. I read something on a different site where someone had the same problem and their issue was a bad climate control unit under the dash. If anyone has any input I'd appreciate it.
Old Jul 23, 2013 | 06:41 PM
MikeM's Avatar
Default Re: 02 MDX blower stopped working in the front
Check for voltage to your blower motor, you can use a dvom or a test light.
Old Jul 26, 2013 | 09:47 PM
95blackLS's Avatar
The blower is receiving voltage. Tested the blower by jumper wire directly to 12V, worked perfect, also has good ground. Performed tests on the Climate Control Unit under the dash and passed. Performed Ohm test on the power transistor and was within spec. Performed jumper test on power transistor according to ALLDATA, blower did NOT turn on. ALLDATA recommends replacing power transistor. I guess after $100 we'll see if it works.
Old Jul 30, 2013 | 08:20 AM
95blackLS's Avatar
Resolved. replaced Power Transistor HVAC fixed the issue
ThatGinjaDude
Dec 21, 2016 10:19 AM
woody7121
May 12, 2015 04:03 PM
NOFX
Mar 30, 2014 10:17 PM
Bangher4$
Honda Civic (2001 - 2005)
11
May 22, 2009 01:25 PM
Ransom
Jun 25, 2004 03:12 PM
