no fuel no spark. 92 accord dx
Old Jul 16, 2013 | 07:59 AM
johndellago's Avatar
Default no fuel no spark. 92 accord dx
I have a 92 accord dx. There is no power going to fuel pump fuel pump relay and there is no spark. Just replaced the ecu fuel pump relay fuel pump fuel filter. It has to be electrical. The local honda dealer suggested the ignitor to be replaced but that wouldnt fix the no fuel issue. Bad ground? Dont know where to start.
Old Jul 16, 2013 | 04:18 PM
dannylegreat's Avatar
Default Re: no fuel no spark. 92 accord dx
Check for breaks in the electrical line. Possible short.
Old Jul 16, 2013 | 10:17 PM
holmesnmanny's Avatar
first thing I would be checking is the ecu fuse
Old Jul 22, 2013 | 01:40 AM
It actually turned out to be neither a fuse or a short. The thermostat was replaced and honda has the main engine ground going to the thermostat housing. The ring terminal broke so i had to splice a new one on. Re ran it to transmission housing and started right up. Helpful hint for anyone with same issues. I would also recommend upgrading wiring from 16gauge to atleast an 8gauge ground. Less resistance.
Rodnie1919
Classic Hondas
Jul 25, 2020 09:07 AM
jgraves16
Jun 24, 2014 10:15 AM
musikpal
Mar 26, 2010 06:08 AM
dabigrog
Jul 12, 2004 06:37 PM
