fuses?????
Old Oct 24, 2002 | 04:45 PM
tunerx's Avatar
New User
Default fuses?????
on my 90 hatch under the dash there is no diagram for what fuse is what?
how do i find out which one is which?
please help
Old Oct 24, 2002 | 05:06 PM
Hondasaurs's Avatar
Default Re: fuses????? (tunerx)
the fuse diagram should be on the plastic cover you remove under te sterring column.
Old Oct 24, 2002 | 05:10 PM
mr. carpenter's Avatar
the panel that covers the fuses should have it written on the inside of it.
if not-
starting w/ 1 which is the left side bottom row of fuses
1- 10 amp, turn signal,back up lamp
2- 10 amp,starter signal
3- empty
4&5- lft rght hi beam
6- 30 amp,sunroof
7-empty
8- 10 amp,tail light,licence light,instrument lights
9- empty
10&11- lft rght lo beam
12- 15 amp,clock,radio,cigarette lighter,interior light
left side top row
13- 15 amp,wiper washer,sunroof relay
14- 10 amp,alternator,solenoid valve
15- 15 amp,cooling fan
16- empty
17- 10 amp,cigarette lighter relay
18- 10 amp rear defroster relay
this is from a '91 std hb
hope it helps
[Modified by mr. carpenter, 2:11 AM 10/25/2002]
Old Oct 24, 2002 | 09:07 PM
tunerx's Avatar
New User
Default Re: fuses????? (mr. carpenter)
there is nothing covering the fuses
it is missing the diagram, how else can i find the fuse i am looking for
Old Oct 25, 2002 | 02:10 PM
look at the fuse panel w/good light. there are numbers by each fuse. these numbers corrospond w/ the numbers in my earlier post. what fuse do you think is burned? where are you in houston?
[Modified by mr. carpenter, 11:11 PM 10/25/2002]
sparrow1
Oct 27, 2015 12:23 PM
TIRENECK
Oct 15, 2012 04:43 AM
zeb1117
Jan 5, 2010 04:01 PM
kotton909
May 25, 2008 05:14 PM
RiCeRTeG
Mar 16, 2005 04:19 PM
