92 civic fuel pump doesnt prime
Old Jul 15, 2013 | 01:44 PM
BmoreEG's Avatar
Default 92 civic fuel pump doesnt prime
I recently replaced my fuel pump in my 92 civic, the old one worked fine but my fuel guage wasn't working so I replaced it. after putting the new one in when i would turn the key on, the pump would prime for about 3 seconds and cut off, but wouldn't build any pressure in my fuel lines. so i took it out to make sure everything was done correctly and now after putting it back in the pump doesn't even prime.. could it be my relay?
Old Jul 15, 2013 | 06:46 PM
teamXteg's Avatar
Icon4 Re: 92 civic fuel pump doesnt prime
have you checked any fuses? under the hood also?
Old Jul 15, 2013 | 06:50 PM
knutdl13's Avatar
Default Re: 92 civic fuel pump doesnt prime
Pull your back seat to access the sending unit cover. Pull the cover, pull the plug, turn the key just before the starter and check for power with an indicator light or a voltmeter. If you have power then its your sending unit
logjammin
17
Jul 29, 2013 07:59 AM
EG92DX
15
Jan 23, 2013 09:41 AM
Tanner67
May 18, 2006 01:28 PM
bigbacon2
Mar 3, 2006 02:52 PM
