Need info on what parts to buy for D15B
Old Jul 15, 2013 | 09:40 AM
turpdawg's Avatar
Default Need info on what parts to buy for D15B
Hello to all. I just picked up a 97 Civic/5spd wiith a JDM engine for my daily driver. I would like to do a tune up, but I am not sure which engine I should buy parts for. The block is stamped D15b, and it does have one VTEC solenoid. What engine should I specify when ordering/purchasing parts for tune up?
First tank of gas with the car as is produced 34.5 mpg. Adjusted tire pressure to spec for the second tank and I am up to 36.7 mpg. I think I am going to love this car!
Old Jul 15, 2013 | 09:49 AM
teamXteg's Avatar
Default Re: Need info on what parts to buy for D15B
nice!! im thinking you can get parts for the Y8 or Z6.. im guessing like the spark plugs, cap, rotor?? i dnt remember if the OBD1-2 cap & rotor are the same. i wanna say they are.
Old Jul 15, 2013 | 10:23 AM
B_Swapped93's Avatar
you get the proper components for you engine/year/obd. for you you'd be after d15b cap+rotor and such.
Old Jul 15, 2013 | 03:16 PM
turpdawg's Avatar
There is a string of numbers under the stamp as well. Would that be a serial #, or actually tell me what the engine came out of? I also saw in yellow paint marker, the kind the salvage yard would use, d15b/AT/EK3. Does it mean anything?
Old Jul 15, 2013 | 03:35 PM
CO671's Avatar
D15b = Engine
AT = Automatic Transmission
EK3 = Chassis code of an EK3 Civic VTI I presume.
Your question has been asked many times btw:
Here's the most useful link:
D15b VTEC FAQ
JDM D15b Vtec replacement parts..?
Water Pump= same as D16Z6
Timing Belt= same as D15Z1
Timing belt Tensioner= same as D16Z6
Head gasket= D16Y8(its the cheapest one)
Front & Rear main Seals= same as D16Z6
Valve cover & Oil pan gasket kits= same as D16Z6
Intake manifold= same as D16Z6
chicaman27
Mar 2, 2019 09:31 AM
panzer948
Jan 28, 2013 10:46 AM
GumballNA
Dec 4, 2002 07:39 PM
976
Oct 17, 2002 06:29 AM
