dome light stays on after replacing door.
Old Jul 14, 2013 | 04:22 PM
Myechtatel's Avatar
Icon3 dome light stays on after replacing door.
so i just replaced my passenger front door on my EK8 sedan. now the dome light stays on. it flickers off when the door is closed but stays on after that. where are the contacts that make the light go off? or do i need to replace something? thank you
Old Jul 14, 2013 | 04:27 PM
Ryan Lwin's Avatar
Default Re: dome light stays on after replacing door.
It's on the side wall. Right below the lock. It's a little black bump. If you push it in while the door is open, you can see the light goes off.
Old Jul 14, 2013 | 05:20 PM
NVturbo's Avatar
O.G. triple O.G.
It's called a door pin switch. Make sure the connector is on the back of the pin switch.
Old Jul 14, 2013 | 08:31 PM
X E Ryder's Avatar
The PO of my car decided to slam the door on (presumably) the seat belt, which slightly dented the area the door's pin switch is. This resulted in my dome light on also.
I cut a 1/2" diameter circle of 1/8" close cell adhesive-backed foam and stuck on the door, dent spot and the light quit staying on (there was no adjustment in the pin switch I could see).
Your door is either not closing in far enough to open the switch / break the circuit or you have a bad switch / dent there.
Not a difficult fix though.
hon0405
Dec 7, 2016 01:29 PM
aalb1
Mar 26, 2009 08:43 PM
jaysin04
Nov 22, 2008 12:44 AM
ravie
Jan 26, 2008 12:38 PM
