ebrake light on dash stays on.
Old Jul 14, 2013 | 11:24 AM
MyB20hatch's Avatar
Default ebrake light on dash stays on.
I have a hard brake light on the dash. It was interment but now it wont go out. I'm thinking it is the switch. Any insight wohld be great. Thanks.
Old Jul 14, 2013 | 11:28 AM
EJ8mike's Avatar
Default Re: ebrake light on dash stays on.
Your brake fluid might be low. You may need new pads.
Old Jul 14, 2013 | 01:43 PM
MyB20hatch's Avatar
Well I sure feel like and idoit. Brake fluid was low. Thanks for the help.
Old Jul 14, 2013 | 01:51 PM
eurochoi's Avatar
Check your pads too. When they wear, fluid looks low even if the same amount is in the system. When you push the pistons back in and you have already filled it up, then the reservoir will overfill out of the top.
Old Jul 14, 2013 | 01:52 PM
HondaPartsHero's Avatar
Technical Hero
Or you could be leaking somewhere as well. Do a good checkup all the way around and at the master cylinder as well.
mintonbt529
Dec 20, 2010 08:20 AM
rleonekc
Mar 2, 2006 11:48 AM
4g4me
Oct 14, 2004 03:50 PM
amh0001
Sep 22, 2004 05:48 AM
crxaddikt
Jul 3, 2002 12:31 PM
