just replaced my timing belt now my enging sounds like its knocking
Old Jul 14, 2013 | 05:07 AM
screamin_demon's Avatar
Default just replaced my timing belt now my enging sounds like its knocking
My title basically says it all. I changed the belt out and it sounded like i had a valve just barely taping a piston but i did a compression test and all passed but i readjusted my cam but im still hearing the noise when i give it gas.
Old Jul 14, 2013 | 05:12 AM
EsotericImage's Avatar
Retired Moderator
Default Re: just replaced my timing belt now my enging sounds like its knocking
re adjust your valves.
Old Jul 14, 2013 | 05:19 AM
How do i go about doin that? My skill level is on the lower end of moderate.
Old Jul 14, 2013 | 05:35 AM
Former User's Avatar
What car and engine?
Is the engine properly timed and the timing belt properly tensioned?
Old Jul 14, 2013 | 05:46 AM
1995 honda civic 1.6 vtech with a 1.6 head swap
Old Jul 14, 2013 | 05:51 AM
grumblemarc's Avatar
The Grumpiest
He asked a question too.
Old Jul 14, 2013 | 07:54 AM
apexi_rsx's Avatar
you could be off a tooth on timing... you did not use the timing marks on the crank pulley did you? its best to use the timing mark on the lower timing gear and the oil pump.
Evan Cronin
Aug 1, 2015 04:29 PM
2gnarly
Feb 27, 2010 08:32 PM
b20integrapower
Mar 19, 2006 02:34 PM
93civicEX
Nov 14, 2005 01:57 PM
