obd1 accord distributor in a crx?
Old Jul 13, 2013 | 06:19 PM
Judge Owens's Avatar
Default obd1 accord distributor in a crx?
Hello,
I am converting my CRX to obd1. I got a obd1 distributor from a 1994 accord. looked like a civic one to me. It mounts up to the block and I plugged it all in with my wire harness.
(I also have an ECU harness to run a p05 ecu...)
The car would not start. It turned over very unusually almost like the battery was dead, when it was fully charged.
I reverted back to obd0 and it fired right up and turned over normally again.
Basically, my question is: will a obd1 accord dizzy work for a d16 civic, or is it giving me these issues?? thanks!!
Old Jul 14, 2013 | 12:49 AM
swordofdoom's Avatar
Default Re: obd1 accord distributor in a crx?
I assume you used a conversion harness for the dizzy and used the P05 with a harness?
Old Jul 15, 2013 | 09:49 PM
update- the distributor grounds out against the head. yes i used a conversion harness. the distributor plugged in and mounted fine but short circuits everything.. would not recommend.
Old Jul 15, 2013 | 10:26 PM
crx_si-r's Avatar
it doesn't work because an accord uses an external coil. so your not getting power to the plugs
DaX
Oct 29, 2018 05:07 PM
sir.rexington
15
Oct 20, 2010 01:48 PM
white92teg
Feb 12, 2010 01:09 PM
88ED8
13
Jan 10, 2005 04:21 PM
