1996 obdII Del Sol Si engine harness uncut!
Hi. I'm selling a 96 obdII engine harness that came off a Honda Del Sol Si. I'm converting the d16y8 to obd1 since I already have the obd1 harness/injectors/alternator so I'm selling the original harness that came with the motor. There are no plugs cut, it was taken out of a running car with no check engines and no problems. This harness is the obd2 harness that unplugs from the engine bay like obd1. You can also use this on obd1 civic since this obd2 harness plugs right into the obd1 harness. All you might have to do is re-pin some wires but essentially everything is there ready to go. I don't really have patience and the know how to be able to re-pin it to obd1 specs if not i would of just used this harness but since I have the other harness it doesn't hurt me to let this one go. {no cut plugs}
Will post pics up by the end of the day.
$120 or best reasonable offer.
Eg5ir1
Jun 17, 2013 07:24 PM
jdmekrobot
Mar 13, 2008 12:13 AM
