Fuel Pressure Regulator?!? Stock with walbro 255?
Old Jul 12, 2013 | 08:11 PM
dirtrider937's Avatar
Default Fuel Pressure Regulator?!? Stock with walbro 255?
Ok, I have just installed a turbo on my 1993 Civic Hatch DX d15B7, now its time to take care of the fuel. I have got a dsm 450cc injectors and a walbro 255 fuel pump. Is the stock FPR ok with the 255? I have an aftermarket FPR but should i even worry about installing it? If I should, can I just run it after the stock one in the return line and just take the vaccum line off the stock one and put on the after market? If I do need the aftermarket one, what is the best way to bypass the stock one, with it still being attached to the fuel rail? I would really like to just splice into the return line after the stock FPR and hook up the new one. But i need to know what i need to do to the stock one in order to do that. (like leave the vaccum line on/off, jam the valve open?) but of course that is only if i do need to even run an aftermarket one with the 255. Some one please help!
Old Jul 12, 2013 | 09:34 PM
mechanix619's Avatar
Default Re: Fuel Pressure Regulator?!? Stock with walbro 255?
Stock is just fine for your setup
Old Jul 14, 2013 | 08:19 AM
turbodcxbro's Avatar
Stock will work fine, don't even think about doubling up and installing the aftermarket one along with your OEM... just askin for trouble. Get a fuel pressure gauge tho and make sure its correct.
Freemananana
Feb 22, 2014 03:40 PM
Budget Racer
Feb 8, 2008 05:26 AM
92DAturboteg
Dec 19, 2006 01:28 PM
redboost10
Jan 5, 2004 12:35 PM
gendai_8
Jul 16, 2003 09:43 PM
