Honda CR-V & Element 2WD & 4WD Element & CR-V
98 CRV crank pulley wobble
Old Jul 12, 2013 | 07:16 PM
swordofdoom's Avatar
Default 98 CRV crank pulley wobble
The B20 crank seems to wobble quite a bit, is this normal?
I have replaced the crank with a new crank and keyway pin but it still does it and its torqued to spec. Completely baffled. I checked the crank itself and everything seems to be smooth.
Old Jul 13, 2013 | 04:34 AM
Sticker Bomb's Avatar
Default Re: 98 CRV crank pulley wobble
No it should not wobble. The crank could be bent right at the end when the pully sits on.
Old Jul 13, 2013 | 03:20 PM
Damn great.........
Old Jul 14, 2013 | 07:34 AM
FasterScooter's Avatar
Or the pulley may not be seated properly, possibly due to wear on the pulley. The other thing it could be is the pulley itself has been damaged.
Old Jul 18, 2013 | 11:23 PM
Two pulleys and same result. I notice when I put the pulley on with the key you can slightly turn it 1 mm before it catches.
civikdude
Feb 13, 2009 02:17 PM
DARKTEG_
Aug 13, 2006 03:15 PM
asefi944
Apr 11, 2005 02:26 PM
