Civic/CRX B16A
14.511 @ 96.4
I/E/C, timing advanced 2 degrees, 94 octane, stripped interior, street tires (not drag radials). 2.27 60' time.
And it runs a 15.1 when VTEC isn't working
14.80 @93 on 16" heavy wheels with POS Nitto 450's.
Full interior, 2350 weight without me.
Stock longblock with ITR cams, and intake manifold. Stock header, GReddy 60mm exhaust, no cat, and a K&N on the throttle body, no Intake. Made 151 at the wheels tuned.
The best I could get my car to, totally stock engine/modification-wise (stripped interior, low gas, advanced timing 2 degrees) was 14.8 @ 92mph... that's with a dryer-tube intake goint to the stock CRX intake box with a K&N drop-in panel filter, and the stock CRX exhaust system and catalytic converter
14.59@95mph
b16a in '90 crx std. 2.38 60'. shitty walmart all-weathers. gutted cat, no muffler, stock exhaust with dc 4-2-1 header with outlet from original d series downpipe welded on. toyota tacoma airbox, k&n cone filter. you know i'm ghetto.
all motor i ran a 15.2 leaving easy off the line cause i had to much wheel hop. with the turbo i ran a 13.5 at 108 with wheel hop and wheel spin out of the hole. now i have traction bars and new tires so i'll find out this weekend what it will do..on 5 pounds it should go high 12's on a clean pass.
I ran a 13.4 @ 100mph , If i didn't put a hole in the tranny it would of went 13.20's easy .
B16a w/ S1
CTR pistons
I/E/H
springs and retainers , chipped ECU 9500 rpm's
Teg Type-R I.M.
slicks
untuned V-AFC
coming soon JG pro series head and skunk2 stage 2 cams . I should be in the 12's then
B16a w/ S1
CTR pistons
I/E/H
Teg Type-R I.M.
slicks
untuned V-AFC
eg_nezay: Is that with slicks? If not what tyres/pressures??
due to my 5lug. But now I got a new time from today and it was 8.5 @ 81.95mph
2.0 60ft
Driven
11
Sep 13, 2004 07:02 AM
jdmDXrex
Oct 21, 2002 12:13 PM
