Power Steering on EK w B18C
Hey people.
So after sifting through 10 pages of threads for the last half hour looking for this info, perhaps posting it as a question might be a bit more productive.
I have an EK with a JDM GSR swap and still have the old D Series PS pump hanging keeping the fluid contained. The PS pump that came with my engine doesn't fit the PS line from the D, obviously, so what combination of parts do I need to make this work?
TL;DR
'99 Civic DX w JDM B18C GSR-What parts to make power steering work.
TL;DR
My ghetto solution:
For my B18C-R I used a CRV B20 p/s pump that I modified. I partially cut and drilled the mounts on the B20 p/s pump to make this work.
I also had to heat and bend the PS line from my D motor in order for it to mate with the B20 pump. All of which is ghetto, but it works. I have a PR3 head so our brackets are different.
The above requires that you properly align the belt, which is a pain in the ***. I used washers as spacers to accomplish proper alignment. When I heated the stock D series P/S line I wrapped a wet cloth around the end that plugs into the rubber hose to prevent heat damage to the rubber hose.
I am hoping someone else provides the "right solution" for you. If none is given try what I did. Good luck
I have the same swap in my car. I'm using a 99-00 Si pump, but unsure of the brackets for head and block. I think I'm using different bracket combo's from different B series. I can't recall, been a while.
Look in my archives or search for pdiggydogg (unsure of username), he actually has a write up for this that I followed.
Hey people.
TL;DR
TL;DR
Per my notes to retain power steering from like 5 years ago:
Lower Bracket:
56994-p30-000
Upper Bracket:
56997-p30-010 si
56997-p73-000 itr
Stock d series power steering lines
99-00 si power steering pump:
06561-p2t-506rm
06561-p2t-505rm
56110-p2t-602
56110-p2t-013
Lower Bracket:
56994-p30-000
Upper Bracket:
56997-p30-010 si
56997-p73-000 itr
06561-p2t-506rm
06561-p2t-505rm
56110-p2t-602
56110-p2t-013
baller status
Oct 26, 2016 09:49 PM
