D15b7 hard cold start/and now bogging/died upon take off
Old Jul 11, 2013 | 04:54 AM
GoldenLeg13's Avatar
Default D15b7 hard cold start/and now bogging/died upon take off
94 del sol. D15b7. Had the issue a week ago and pulled the plugs. Found oil on top of plugs. I replaced the plugs and cleaned inside of the wires with brake cleaner. Car then started and ran perfect consistently for about a week and then the cold start issue started coming back and getting worse everyday. Today I baeely got her started and 5min down the road while taking off at a light it bogged out and died. First time its done that. Got her started again and rode high rpms in 2nd for a block untill I got to work.
Any help is appreciated.
Old Jul 11, 2013 | 06:44 AM
Kid-jdm-teggy's Avatar
Default Re: D15b7 hard cold start/and now bogging/died upon take off
Replace valve cover gasket, reset ECU maybe?
Old Jul 11, 2013 | 08:11 AM
Yea I'm sorry I forgot to mention that when I replaced the spark plugs I also replaced the valve cover gasket as well as the spark plug tube gaskets.
The car is good to go all day once I start it and drive it to operating temp for a few min. But when she sits over nite and I come out to go to work I always have issues.
Old Jul 11, 2013 | 05:09 PM
Quick update. Car died as i was getting off the highway. Bogged down tremendously and a homeless dude helped me push it into a lot. I pulled the spark plugs and 2-4 cylinder plugs were covered in oil on the bottom. Cleaned them off and car still wouldnt start. Had it towed home.
Old Jul 12, 2013 | 03:29 PM
Then you need to replace the lower o-rings if there is oil in the spark plug chambers. Maybe the oil kept leaking in overnight so when you let it sit, a lot of oil gets in. It could also cause your car to bog cause its not sparking to ignite the fuel
Old Jul 15, 2013 | 03:17 AM
Update- I feel pretty stupid. Previous owner had just over a quart too much oil in the car. Dizzy had catostrophic failure at the same time. Car is up and on the road
gratua
46
Mar 5, 2012 07:55 AM
KGB_JDM
Dec 1, 2009 11:50 AM
bale43kn
10
Apr 25, 2007 07:59 AM
dailydriven91ex
Jul 19, 2004 06:50 PM
