92 95 civic hatch d15b heeelpppppppp!!!
Old Jul 10, 2013 | 01:50 PM
crazyLemons4.20's Avatar
Default 92 95 civic hatch d15b heeelpppppppp!!!
honda tech helppp!!!!!!! i did a tune up my single cam and now it only cranks but no spark i changed the igniter it didnt work i also changed the ignition coil no difference and ended buying a new dizzy and my **** isnt making any progress can any one help me out pleaseeeeeeeee!!!!!!!
Old Jul 10, 2013 | 01:54 PM
dafreeeze's Avatar
Default Re: 92 95 civic hatch d15b heeelpppppppp!!!
Did it have spark before the tuneup?
Old Jul 10, 2013 | 01:55 PM
yes it did it turned on and everything
Old Jul 10, 2013 | 02:00 PM
grumblemarc's Avatar
The Grumpiest
Did you screw up the firing order?
Old Jul 10, 2013 | 02:34 PM
its not the firing order theres no spark
Old Jul 10, 2013 | 02:37 PM
dafreeeze's Avatar
Well you said it worked before so maybe one of your new parts is no good try changin one by one
Old Jul 10, 2013 | 03:31 PM
Cynical 1's Avatar
did you put the rotor and distributor cap on correctly?
Old Jul 10, 2013 | 03:38 PM
The Grumpiest
Was this actually verified?
I've done I don't know how many tune-ups, as to most of us and never had an issue.
Old Jul 10, 2013 | 04:44 PM
im sure theres no sparks ....sombady haalp!!!!
Old Jul 10, 2013 | 04:51 PM
jdmh22eg2's Avatar
well if it had spark BEFORE you tuned it cltake tune out and put ALL part back on it had. as saying goes regroup and punt
Old Jul 10, 2013 | 05:35 PM
B_Swapped93's Avatar
did you remember to plug the distributer back in....any fuses blown ?
Old Jul 11, 2013 | 09:01 PM
my car turned on today i changed the coil in the other dizzy i bought and my car turned on, but later the same day it decided not to work no more spark and on top of that my turn signal wont work now either!!! my car is retarded helpp
Old Jul 11, 2013 | 09:08 PM
sounds 100% like a bad ground/grounding issue. just today my GSR decided to not start jiggled the batt to chassis all was good have since replaced that ground.
Old Jul 11, 2013 | 09:13 PM
94civiccpe's Avatar
+1 I agree I had a bad ground and my car would do odd things like cel would come on for no reason I went out and checked the thermostat ground and it was rusted fixed it and no issues.
Noo_Ish_mee
Jun 27, 2016 02:44 PM
ex_ricer
Aug 14, 2008 02:14 PM
quick87crxsi
Jan 16, 2007 04:45 PM
VvPeachyvV
Jun 15, 2006 09:59 PM
b18civicgsr
Mar 9, 2005 10:01 PM
