ls into ef sedan
I have a ef sedan shell I bought it running but dropped engine for a swap so I went ahead an bought a 94 acura Integra sedan as,a donor car I know u need the mounts an obd0 to obd1 conversion an also the dpfi to mpfi but other then that is there anything else I would need my Integra is currently running as well...
B series swap mounts, 90-93 integra rear t bracket, hydro clutch conversion (if using hydro trans), 4 wire O2, distributor adapter for whatevr OBD you will be using
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
pushinlsteg
25
Apr 29, 2012 02:50 PM
freakystyley_73
54
Mar 27, 2007 04:03 PM
SiR831
Apr 22, 2004 08:48 PM
