Timing off or need more fuel?
Old Jul 10, 2013 | 05:46 AM
91 EF DX's Avatar
Default Timing off or need more fuel?
I rebuilt a d16a6 for my sedan. The sedan was dpfi and I haven't got the parts to swap it to mpfi yet. When i rebuilt it I put zc pistons in it to give it more compression. The cr is around 10.4:1. My problem is I have like no power from idle to about 2300 rpm. After that it pulls pretty good. My ? is, is this more likely timing or the fact im still running dpfi. Im leaning more towards timing. Im going to recheck timing tonight when I get off work.
Old Jul 10, 2013 | 08:55 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Timing off or need more fuel?
Since you are checking timing when you get home, maybe wait until then to see if you still even have a problem.
Old Jul 10, 2013 | 09:05 AM
91 EF DX's Avatar
Thats what Im thinking it is. From the research I've done its probly off a tooth. But can the motor run fine with no problems with that compression and being dpfi?
Old Jul 10, 2013 | 07:44 PM
turn&burn89's Avatar
that is a good point man, but if it changes after 2300rpm i dont think thats an issue. its by chance an automatic is it?
Old Jul 11, 2013 | 05:34 AM
91 EF DX's Avatar
No its a 5 speed. And when i change to 5th it pretty much loses all power unless i keep it rev up b4 i shift.
Old Jul 12, 2013 | 05:41 AM
91 EF DX's Avatar
Well its been raining for 3 days straight, so I haven't been able to check the timing yet. But hopefully the rain will let up today.
Old Jul 12, 2013 | 05:49 AM
crxin's Avatar
does the car idle good? How do the plugs look?
crxin's Avatar
what type of gas are you running?
Old Jul 12, 2013 | 11:15 AM
91 EF DX's Avatar
It idles fine. and im running 87 octane.
Old Jul 12, 2013 | 12:16 PM
EFlovin''s Avatar
Run 89 minimum IMO anything over 10:1 compression you shouldn't cheap out on.
spens 91 Ef's Avatar
i wish i could she you guys how this guy just copied and pasted off his other post in the nas *** section.
if you truly rebuilt your motor youd know to check your timing. bro i was just like you back in the day thinking i could make my dpfi even fun lol...... you cant i ran a 272 cam and a zc head and had every issue your describing before and after i got the cam. get mpfi. and if you did raise your compression your motor would be pinging from pre det
Old Jul 12, 2013 | 12:41 PM
91 EF DX's Avatar
I copied it from here and posted in the na section b/c no one was responding I thought I would get a faster response in there. So There is no way I can run it like is even if i run high test until i get all the stuff to do the mpfi conversion. Its hard to get parts around here bc everyone wants an arm and a leg for everything and the upull its are usually lacking the parts i need.
If it will help Ill try to post a video up this weekend of it idlein.
Old Jul 12, 2013 | 12:54 PM
i gaurntee its your issues even if you do need more fuel theres now way in providing it thru dpfi, and timing off a tooth you wont even notice it. i paid upwards of 500$ for my mpfi setup and thats obd0. remember mpfi only came in the si's those are rarer then your dx
Old Jul 12, 2013 | 07:01 PM
91 EF DX's Avatar
I was going to go obd1 bc they are eaiser to find and i already have the jumper harness from dpfi obd0 to mpfi obd1. the hardest part is finding a complete intake with nothing missing. what be the best ecu to run? And the timing is off by looks to be 2 teeth. could that make a diff?
Old Jul 13, 2013 | 09:49 AM
91 EF DX's Avatar
Fixed the timing and it seemed to fix all the problems. Now I have shaking in the front end. Is this more likely the outer or inner tie rod ends or the rack bushings?
Old Jul 15, 2013 | 04:18 AM
crxin's Avatar
could be neither, under what conditions does it shake? Hard acceleration, turning, just crushing????
Old Jul 15, 2013 | 05:07 AM
jdmjunkieXL's Avatar
ex sedan is also mpfi
Old Jul 15, 2013 | 05:40 AM
91 EF DX's Avatar
It shakes all the time at all speeds. I pretty sure its the axels. I had the car in the air and checked each tire for play and everything seemed tight. And I know the axels are shot anyways. All the boots are torn and they clicking all the time
91 EF DX
Jul 12, 2013 07:04 PM
S@nt0s
36
Oct 14, 2005 07:02 PM
P1mpSlap
Jul 29, 2003 10:17 PM
Pcart
Oct 11, 2002 12:33 PM
