bent Axle?!
Old Jul 9, 2013 | 06:30 AM
BIGef's Avatar
Default bent Axle?!
This is how it all started. My steering wheel vibrates up to 45 mph and up.
Right after i strolled to my buddies house and did a small burnout then just parked and shut off the car.
When i was about to leave my car started wobbling even just going 5mph and so....
Went home since i live 1 block away so i just drove slowly.
So i jacked up the car and started inspecting it by turning the wheels by hand and i noticed a wobble on the wheel.
So i started the car and let it spin. Noticed alot of wobbling on the wheels. Front driver side passenger side is fine -_-
So i started shaking the wheel left and right no play at all.
New inner and outer tie rod
Tried 2 diffrent steelies
Could this be bent axles?.
Heres small vid of me just spinning the wheel by hand
Old Jul 9, 2013 | 08:17 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: bent Axle?!
My honest opinion/observation...
For your wheel to even be able spin like that the inner and outer race of the wheel bearing (located in the knuckle/hub) would have to be misaligned (no longer parallel with respect to the flat sides).
Old Jul 12, 2013 | 09:33 AM
BIGef's Avatar
24TEN you might be right.
well i went ahead and swapped out with new axles nothing changed.
So i had a spare knuckle and everything is good.
thanks
Old Jul 12, 2013 | 10:13 AM
24TEN's Avatar
PHANTOM MENACE
Glad it all worked out.
.BigSexy
39
Sep 10, 2013 02:57 AM
mxl36o
Mar 28, 2009 06:53 PM
buzlink
16
Oct 18, 2007 07:41 PM
ITRDC2R
Jun 1, 2007 05:43 AM
jdmazm
Apr 28, 2005 07:57 PM
