exhaust/cat questions.
Old Jul 8, 2013 | 10:18 PM
boostit2120's Avatar
Default exhaust/cat questions.
The si I just recently got has hks hi power exhaust on it with 2" piping. The cat was hollowed out so im replacing it and thinking of getting the magnaflow cat and im also getting dc sports stainless steel 4-1 header. Do I need to get a flex pipe or will the header and cat meet directly and not give me enough room for one? Also, does anybody know if the cat comes with the flange that connects to the header that has springs and bends or do I have to get a flex pipe? Thanks.
Old Jul 9, 2013 | 12:23 AM
EX Coupe 98's Avatar
Default Re: exhaust/cat questions.
This one is for Calif. http://www.magnaflow.com/02catalytic...irectfit=46628
And yes the DC Sport header and cat meet directly or you can get one without the flange.; http://www.magnaflow.com/02converters.asp A cat without the flange you could do a custom install with flange on one end of the flex pipe to the header.
Old Jul 9, 2013 | 08:43 PM
So a cat with the flange on one end to connect to the piping and then a flex pipe welded to the cat and a flange on the other end connecting to the header? What size flex pipe would I need? The piping is 2"
Old Jul 9, 2013 | 08:44 PM
Cause im pretty sure the cat dont come with the spring loaded flange so the exhaust cam move without causing cracks. Or does it?
Old Jul 11, 2013 | 04:52 PM
I have had my DC Sports 4-2-1 header connected to the stock Cat. (flange to stock spring loaded flange) no flex pipe for 7 1/2 years and over 83,000 miles and NO cracks, and that is with stock motor mounts (lots of movement).
Take a look hear; http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
If it was "me" i would buy Part #20 /1ea. #21 /2ea. #23 /2ea. #33 /2ea. and be done with it. but maybe someone out there has a better way to do it.?
I hope this helps.
Old Jul 11, 2013 | 06:22 PM
B_Swapped93's Avatar
since when did a HKS hi-power system come in 2'' piping, that's smaller than stock on the Si....
honda95civic
Welding / Fabrication
Aug 28, 2005 05:31 PM
integra_94
Aug 30, 2004 09:35 PM
GS-R_nut
Apr 2, 2002 05:50 AM
bananacruzier
Feb 14, 2002 10:50 AM
