Speedometer reads too fast
Old Jul 8, 2013 | 09:50 PM
thunderstrikes's Avatar
Default Speedometer reads too fast
I just acquired a 95 accord. The speedometer reads 70, but I am actually only going 60. Where do I start looking to fix this? Thanks for your time !!
Old Jul 8, 2013 | 10:00 PM
jbpnoman's Avatar
Default Re: Speedometer reads too fast
You can start off by posting in the correct section. This is for Civics, not Accords.
Past that, make sure you have the correct wheel/tire size on the car, as well as the proper transmission and speed sensor.
Old Jul 8, 2013 | 10:01 PM
CO671's Avatar
1) Wrong section, here's the Accord section for your generation:
https://honda-tech.com/forums/forumdisplay.php?f=2
2) Speedometer calibration (if it's the cluster that's malfunctioning) isn't simple and easy, is there a CEL (check engine light) [#17 or #4] If so, it could be associated with a VSS problem (Vehicle Speed Sensor). The VSS is connected to the transmission and has a gear which measures vehicle speed.
Old Jul 9, 2013 | 03:06 AM
belairbrian's Avatar
First explore the suggestions provided.
But, what is the error at other speeds?
When I bought my Del Sol it was 7 miles off at every speed. My fix was to remove the lens from the dash, remove the needle, then
Drove in 3rd gear and found the rpm that generated 30 mph GPS. Made several passes to verify.
Drove at a steady speed and replaced the needle.
Took a couple trys but now it is within 1 mph against GPS at all sppeds.
Old Jul 9, 2013 | 03:18 AM
cetcivic's Avatar
no one wants to hear the truth
First off,how are you so sure the speedo is fast?
You can check your driver side door jamb for proper wheel/tire size for your vehicle
Is the motor/trans original?
Old Jul 9, 2013 | 06:05 AM
sleepyaccord96's Avatar
94 to 97 accords always read off on the rpms and speedo... remove the cluster and adjust it via calibration setting screws located in the backside of the gauge cluster.
Old Jul 9, 2013 | 03:27 PM
Thanks everyone for all the helpful Information. I will start checking those Items from easiest first. Sorry about posting in the wrong section, I will get my eyes calibrated while I am at it!
Old Jul 9, 2013 | 04:17 PM
For the specific car info that was asked:
Tires are P185/70R 14
1995 Honda Accord LX L4 2.2L type F22B2 4-Speed Automatic
Old Jul 9, 2013 | 08:09 PM
I determined the speed variance by pacing some newer Honda vehicles. Since I got the car used, I do not know if this is the original motor / trans and the car lot I got it from does not know either. There is no check engine light, so looks like speedometer calibration will be the way to go. Just ordered a service manual, so I think I should be in good shape. Thanks again for all your help!! Have a GREAT day !!
janelectric
Aug 27, 2012 06:04 AM
Rat Rod
Nov 18, 2010 04:02 PM
aziaticvang
Jan 13, 2008 06:35 PM
aws140
Aug 17, 2005 07:08 PM
WuWarrior
Jan 28, 2003 11:55 AM
