Suspension noise please help
Hi I have a 96 accord ex and I've been having this weird creeking popping noise in the frot end for awhile. The noise happens when turning and when you come to a stop and let off the brakes it happens. The car is lowered on spring and aftermarket struts with 215/45/17 tires. And I took the power steering off. So far replaced power steering rack. Outter tie rods sway bar links upper strut mounts strut bearings upper control arms and ball joints and lower ball joint on driver side. The car does have a torn C/V boot on passenger side and a bad motor mount in the very front of engine does any one have any ideas please help
did you use moly grease on the sway bar bushings ? ...take the front driver wheel off and put it on a jack stand ...grab engine at oil pan and shake it front to back...if the engine shakes the rear mount is bad
also could be the bushings for the rack...use a crow bar to try to pry it and see if it has movement/clunks
EM1 Loi
Jul 31, 2008 09:15 AM
