wont start sometimes issue help
Old Jul 8, 2013 | 05:39 PM
barnchips's Avatar
Default wont start sometimes issue help
its a 1994 hatch with a boosted b18 swap
ok so randomly the car would not crank over at all u hear i believe one click and thats it , other sometimes it takes a few turns of the key and it will finally fire so .....
I tested the battery and it checked out
I put in a new starter still problem
i re did the wires and got new terminals and a new battery still same problem
however.... when i add the battery charger to the battery and then crank it it will always start not sure whats going on any idea ?
Old Jul 8, 2013 | 05:51 PM
CO671's Avatar
Default Re: wont start sometimes issue help
Double check your grounds. Starter and transmission grounds especially.
When you put in the new battery(ies), did it start instantly? I'm assuming there could be something draining the battery after a while when the car is off and it's not enough to crank when you try to start it again.
Old Jul 8, 2013 | 06:02 PM
B_Swapped93's Avatar
cheeked the main relay and that the solder points are good ? last ignition system tune up ?
Old Jul 8, 2013 | 06:04 PM
barnchips's Avatar
guess i will check the grounds , not sure what would be draining it , but ya maybe something is cause it did start with the new battery right away , but I only parked it for like 4 mins and it wouldnt start the next time , does the actual power wire have a ground from the battery to the starter , cause mine has some like brackets on the outside of the wire that are just going to nothing , not sure if they used to bold to the car some place I dont think thats a ground , but i will check the actual starter ground and tranny maybe just wire brush those connections ?
Old Jul 8, 2013 | 09:11 PM
barnchips's Avatar
well I'm not sure where the ground wire is for the starter , I see the main power wire too it , and then the small wire that I thought turned it on and off , but not sure on the ground part ....
however I cleaned the battery ground , and the tranny ground really well they were kinda dirty i polished it and so far the car is starting each time its done this before tho so i don't fully trust it yet crossing fingers that that cured it lol
Old Jul 8, 2013 | 09:21 PM
Former User's Avatar
There are two ground wires for the starter - the G3 transmission ground and the G1 battery ground. But it sounds like you cleaned and tightened them and that your problem may now be fixed.
Old Jul 19, 2013 | 11:30 AM
barnchips's Avatar
problem is back : ( , I put in a new ground wire and battery , the car starts to gradually lose battery power so it must be a short of some sort , I am going to disconnect the power wire to my stereo see if it goes away then try alarm this is gonna be a head ache any hot tips for tracking down a short in the electrical system ? thanks
Old Jul 19, 2013 | 11:34 AM
poprocksncoke
Jan 28, 2017 04:56 AM
JDM_95_LS
17
May 24, 2011 07:43 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
jorge59la
Sep 16, 2007 06:28 PM
tan2
Nov 4, 2002 10:10 AM
