G22 build compression question
Old Jul 8, 2013 | 01:09 PM
Nero 94 Accord's Avatar
Default G22 build compression question
I have a f22b2 block and a h22a4 head I know when you put it together it has low compression but what kind of pistons can I use to bump up the compression
Old Jul 8, 2013 | 01:54 PM
GhostAccord's Avatar
Default Re: G22 build compression question
Any F22B2 85mm aftermarket piston that has a higher dome volume will raise the compression accordingly. Wiseco, Arias and CP all make them.
Taking into consideration that you are building an OEM hybrid. I suppose you are looking for an OEM cast piston that you can throw in there for cheap. Try an 86mm bore and use a K20a1 piston. They have am 86mm diameter and 4.25cc dome with a compression height of 30mm.
That should effectively raise your compression to 10.8:1. 11:1 if you do some minor head & block milling.
Now in saying that you won't be able to use floating wrist pin pistons (H22/H23/K20/K24) without modifying your F22 rods.
Old Jul 9, 2013 | 07:19 PM
So to use the k20 pistons the block just needs to bored out to 86 mm?
Old Jul 9, 2013 | 07:42 PM
DeadlockRiff's Avatar
Yes, it will need to be bored and honed. Remember that you'll need to modify the rods to accept the different style of wrist pins.
Boring out the engine will take it from 2156cc's and bring it to 2207cc's. If you bore it to 87mm it can accept H22/23 & K24 pistons which will raise it to 2259cc's (2.3L).
I do not know the specifics in their dome displacements and comp heights but I'll try and remember to look into it if someone doesn't chime in with the numbers soon.
Old Jul 10, 2013 | 03:14 AM
K how do I make the modifications to the rods
Old Jul 10, 2013 | 03:32 AM
You have to take them to a machine shop and have the piston end honed (enlarged) and fitted with a bronze bushing.
dc2-millano-red
14
Jan 1, 2014 05:48 AM
JTR_HATCH_EG
Dec 23, 2012 05:10 PM
H23civichatch
Apr 28, 2009 06:51 PM
lunch_box_4_life
Sep 25, 2008 08:27 AM
Si Integra
Feb 11, 2004 02:29 PM
