Thoughts on my suspension setup .. :D
Old Jul 7, 2013 | 01:11 PM
KennyVtecMey's Avatar
Default Thoughts on my suspension setup .. :D
Hey fellow Hond-Tech.
I have a 1990 Civic Si, Very clean for a 20+ Y/O car.
It isn't perfect but I have huge intentions with it!
Heres some pictures through via Instagram:
http://instagram.com/kennyvtecmey/#
*Disreguard other dumb and irrelevant posts, I'm unable to post on my computer because, well idk, and I don't care right now*
My main topic on this thread is to get the opinion and the thoughts on my suspension plan to you guys, to see if its worth my hard earned money.
Coilovers : Function & Form Type 1
http://www.jhpusa.com/store/pc/viewP...idcategory=559
I am looking maybe at a 1.5 - 2.00 Inch drop? I'm not sure yet.
Lower Control Arms: Function 7:
http://www.jhpusa.com/store/pc/viewP...idcategory=443
I know the Function 7's are pricey, but I'd much rather purchase a high quality suspension part now and not have problems, than spend less and have problems, thus spending more money.
That's pretty much it for my suspension kit, let me know if I am going to need anything else.
My EF is rust free on the shell, but it has some surface rust (Florida Car), but it is again an old vehicle!
And I am most likely going to purchase Si Blades from a em1 so im not going to be "Hellaflush" haha.
But again let me know what you guys think, or what I should get different.
Old Jul 7, 2013 | 01:18 PM
Tyson's Avatar
Default Re: Thoughts on my suspension setup .. :D
you sound like a kid who wants to waste his money.
... you asked.
Old Jul 7, 2013 | 01:36 PM
Bently_Coop's Avatar
Steve at Heart
save your money, unless your going to be tracking your car the lca's aren't going to help, those coilovers are also known to leak, and just for people who want to be low.
Old Jul 7, 2013 | 03:21 PM
crvtectim's Avatar
Start your suspension mods by reading here: https://honda-tech.com/forums/suspension-brakes-54/click-here-all-you-curious-about-suspension-setups-their-costs-reliability-2967499/
Old Jul 7, 2013 | 03:43 PM
b16lewis's Avatar
what are you intentions for the car
Old Jul 7, 2013 | 08:03 PM
EFlovin''s Avatar
Koni yellows/ground control or GTFO... No I am just playing. But seriously... Koni/GC
Old Jul 7, 2013 | 08:21 PM
I just want a daily driver , but I don't mind spending money on good parts. I just wanna lower it the "right" way.
Old Jul 7, 2013 | 08:29 PM
I wouldn't mind saving money, I am just thinking about the money spent overtime if I get shitty parts.
I wasn't 100% set on the coilovers and lcas , what setup should I run. I'm looking for a 1.45-2" drop, for daily driving.
Old Jul 7, 2013 | 08:51 PM
Tyson's Avatar
Start with basic maintenance on the car.
Making sure brakes are good with fresh fluid, replace any ball joints that have play, buy new tires, then evaluate what's really needed.
And unless it's already been done recently, the steering rack needs to be rebuilt.
Old Jul 8, 2013 | 10:40 AM
F22Master's Avatar
Koni/GC or Progress coilovers
And IMO, all LCA's are the same... They are all just a piece of machined aluminum with 3 bushings.
Old Jul 8, 2013 | 11:45 AM
category5's Avatar
^^^What this guy said...especially the steering rack part.
Old Jul 8, 2013 | 12:27 PM
F22Master's Avatar
Just to clarify, by rebuilding the rack, do you just mean the rack end bushing? Any other parts required?
Old Jul 8, 2013 | 12:51 PM
ssydmonk's Avatar
Newbie user and car guy. Just recently bought a '91 CRX HF for the MPGs. I'm interested in finding out what I should check on the car to make sure I get the best MPG possible. It seems to be getting 40ish on the Interstate.
What's the opinion and reasoning behind requiring a steering rack rebuild? Do they have a tendency to wear out?
Old Jul 8, 2013 | 01:04 PM
Everything in the car is well. I've had the car for well over a month and have had all that good stuff checked out. Thanks for the input.
Old Jul 8, 2013 | 01:12 PM
Todd00's Avatar
I said I don't want a title!
Skip the sh!tty coilovers (they are POS's) and the bling rear LCAs (pointless) and start with maintenance items.
Then, pick a good shock (like a Koni yellow) and quality lowering spring and have a nice daily that'll provide years of enjoyment and reliability.
Old Jul 8, 2013 | 05:43 PM
Steve at Heart
Bushings, ball joints, tie rods and similar stuff will help. Look at either hard race or energy suspension. Both decent company's and will definitely firm it up with a good set of struts and coil overs.
Old Jul 8, 2013 | 08:20 PM
Thanks guys! I planned on doing energy suspension poly bushings before all the suspension work. I will also look into Koni's and make sure my suspension is a.o.k.
Old Jul 9, 2013 | 09:40 AM
Tyson's Avatar
energy suspension is a good way to bind your suspension. cheap, takes lots of work, and wear out quicker than rubber.
nothing beats OEM rubber bushings for daily street application.
Old Jul 9, 2013 | 10:05 AM
bbarbulo's Avatar
koni yellow and some kinda nice spring (H&R, progress, etc...)
or Progress or AMR coilovers
yes for the LCAs... I have a set, and they are beautiful. useless, but beautiful. treat yourself.
Old Jul 9, 2013 | 10:09 AM
JuggerNaut-CTR's Avatar
Energy bushings really, really suck!
Old Jul 9, 2013 | 11:41 AM
F22Master's Avatar
^QFT.
Old Jul 9, 2013 | 10:29 PM
Bolinkxr's Avatar
On my 91 hatch I went with e the energy suspension bushings and a set of skunk2 pro seres coil overs . The reason I went with them is because they are setup for my specific car on the damping and spring rate by skunk 2 testing. I trust they will do a better job them me .so far there are grate I I'm really happy with them all i had to do was set the ride hite can't what to get them on the track
eBay buy $620
Old Jul 9, 2013 | 10:51 PM
Red-Rocket's Avatar
For a 2 inch max drop, I'd go with Progress CSII coil overs with 350/250 spring rates they cost just as much as the f&f coils ($595 through the marketplace) but are leaps and bounds above them in quality, unfortunately they are always on back order. I'd keep the stock LCAs, press in new oem bushings, get a good sway bar and have a fun daily.
Old Jul 9, 2013 | 11:33 PM
Thanks for the input ! Il take that into consideration and do more research before I finalize my purchase.
Old Jul 10, 2013 | 01:27 PM
DCRB's Avatar
i would go knoni yellow/ground control for dropping your car. best bang for your buck suspension, and the ride quality is still great. the f7 LCA's are the only after market lca's i would rock after using blox ones. took them off after two years, bushings are almost all disintegrated and are all torn up. stay away from them. oem works fine, but yes they aren't that bling blingy. more bling attracts more thieves though
