h22a in 99 civic ex?
Old Oct 24, 2002 | 01:04 PM
DaBuccaneer Fan
Guest
Posts: n/a
Default h22a in 99 civic ex?
next spring in I plan to perform an h22 swap... i have heard about the suspension issues and they can be easily reconciled,but i heard i will loose my power steering.
I want to keep it, but how?
Old Oct 24, 2002 | 01:16 PM
poison's Avatar
Default Re: h22a in 99 civic ex? (ApacheNYC)
ya you will have to get rid of power steering. I was stumped on this fact as well before I did my swap.
But, when you take off power steering, trust me, the car feels much better as for turns and such non-power assisted.
Reason being it will not fit (although I could be wrong if I am sorely mistaken), but the EK/J engine bay is just slightly bigger than EG/J engine bay.
Currently, there is no bracket for having power steering, and the prelude's/accord's will not fit due to hood clearance and radiator support clearance.
Let alone getting a belt up there when there is barely any room between the frame rails.
Old Oct 24, 2002 | 01:23 PM
rob d's Avatar
I don't see why not. I have PS in mine (94 ex with h22). I had to cut my rad suport and make a custom line. I works great.
Old Oct 24, 2002 | 01:33 PM
poison's Avatar
Default Re: h22a in 99 civic ex? (rob d)
impressed
there are ways around it, and of course, some fabrication.
I dunno how the hell you got that power steering main line to the pump, but props
Old Oct 24, 2002 | 01:38 PM
rob d's Avatar
Default Re: h22a in 99 civic ex? (poison)
I just cut my main line and welded the h22 line to it.
Old Oct 24, 2002 | 05:31 PM
youngkow's Avatar
Did you use a custom bracket for the power steering pump? Also what engine mounts are you using? I called HASport today, and the person told me that they are coming out with the EK-H22 mounts in about two months and u can use the prelude ac condensor? and the power steering pump.
Old Oct 25, 2002 | 02:47 AM
rob d's Avatar
Default Re: h22a in 99 civic ex? (youngkow)
I used the h22 pump and bracket. Its a tite fit, but it clears the hood. I'm using the HASport mounts. I know they are working on a bracket for the stock EG/J ac compressor. I dont know about the h22 condensor. I tried to hook up the ac using the h22 compressor. It hits the frame rail. I would have to bang the frame rail out a little to make it fit. Also the EG/J condensor hits the altanator. I have seen AC in the EK/J-22 but not the EG/J-22. You have more room in the EK.
Dave01
Feb 4, 2004 06:11 AM
EK22Tim
Sep 1, 2003 05:07 PM
Eggman
Jul 12, 2003 01:20 PM
Drkaccrd
May 23, 2003 09:53 AM
