Wheel Lug Nut Q:
Old Jul 6, 2013 | 08:39 PM
Dingrz's Avatar
Default Wheel Lug Nut Q:
Hey guys I'm just wondering if Rays Engineering Wheel Lug Dura Nuts would fit my 98 civic hatchback?
Lug Nut sizes:
Length: 50mm
Size: M12 x 1.25
Cheers,
Dingrz
Old Jul 6, 2013 | 08:43 PM
CO671's Avatar
Default Re: Wheel Lug Nut Q:
Should be 12x1.5
IIRC, 12x1.25 are for Subaru's/Nissan's
Also, when purchasing lug nuts, there's different types of seats for different wheels too.
What wheels are you using?
The "seating area" (or "seat") is the area of the lug nut, and the area of the wheel, that come in contact with each other. Stock Honda/Acura wheels have a ball/radius/spherical shaped seating area, and need lug nuts (such as stock lug nuts) which also have the same shaped seat. After market wheels use a tapered/conical/cone shaped seating area and need lug nuts (including most tuner lug nuts) which also have the same shaped seat. No, it is not safe to mix and match (stock wheel with tapered lugs or vice versa); the contact between the lug nut and the wheel will be insufficient, putting undue stress on them and potentially causing failure.
Old Jul 6, 2013 | 08:46 PM
Dingrz's Avatar
Ok cheers mate, im using king sabeth 15"
Would that be the tapered seat?
Old Jul 6, 2013 | 10:18 PM
jbpnoman's Avatar
Take one off and look at it.
showcivic2001
Oct 17, 2008 04:14 PM
Partizan
Oct 15, 2008 05:25 AM
accorkie
Jul 31, 2007 09:23 AM
G'Funk
May 6, 2007 09:17 AM
alexsracing
Oct 20, 2006 09:14 AM
