F/S F/T CIVIC EK SHELL W/B16 TRANS NEEDS ENGINE! HAS MODS! REGISTRATION CURRENT!
Old Jul 6, 2013 | 07:56 PM
AL1222's Avatar
Default F/S F/T CIVIC EK SHELL W/B16 TRANS NEEDS ENGINE! HAS MODS! REGISTRATION CURRENT!
FOR SALE OR TRADE. WILL ONLY TRADE FOR RUNNING CARS! HONDAS AND ACURAS ONLY PLEASE!
1998 Honda Civic EX 5 speed manual that is set up for a B series motor! The car is a complete rolling car minus the motor! No motor included! This 1998 Honda Civic EX holds a California SALVAGE Title due to a frontal accident, Car is fully registered till September 8, 2013 still a few months till the registration expires. Have title on hand ready to be registered, 2 keys and 2 alarm remotes are also coming with the car
Read down below and please look at the pictures. If there is anything that I have not included in this listing or did not make it clear please feel to message me or call me directly 657-200-0777.
I can even answer your questions via text at the number provided. You are more then welcome to come look at the car by appointment only.
PRICE IS FIRM 1750.00 CASH ONLY! IF YOU MESSAGE ME OR LOW BALL ME YOU WILL BE IGNORED! PLEASE SERIOUS BUYERS ONLY!
Exterior Condition
Paint on this civic is pretty good, as i stated this car was in an accident and it looks like it was painted before. from the doors back the paint still shines, with a bit of wet sanding and buffing this car will look good. No key marks or deep scratches! The front of the car was replaced with aftermarket parts besides the hood its oem and the paint still shines and looks good. Fenders on the car are white but do not match the cars paint 100%, there are a few small dents on both fenders. I have one OEM right fender that is white has no damage dents wise but will require paint. I recommend replacing the left fender instead of fixing them because the parts are so cheap aftermarket. Bumper has a small indent, can easily be fixed or you can replace the bumper as well probably cheaper to replace then to fix. Body from the door back have a few dings here and there nothing big just door dings no big dent, only dent this car has is on the right rear corner where the trunk lid meets the panel. This car does not need major body work, replace fix both fenders i am including one already, replace fix bumper and the small corner on the panel thats it and you will have a really nice looking car. Windsheild broken must be replaced
Aftermarket parts or mods
- JDM Turn Signals
- JDM Fog Lights
- Black Aftermarket Head lights
- HID's 6000K
- 99-00 civic Si Tail Lights
- Adjustable Omni Camber Control Arms
- Eibach sport line springs 1.8 in drop all around rides nice
- 16in Drag dr-16 with brand new off brand 205/45/16 tires, wheel locks with key included.
- Exedy Stage 1 Clutch (part number on the clutch disc HCD015U) includes pressure plate, disc & alignment tool
- JDM p30 Chipped ( Running OBD1 Tune )
- AEM Short Ram Intake
- B16 Trans ( 75K on Trans )
- Stock SI mounts ready for B series Swap
- No Name 4-1 Header (dented at the bottom still usable)
- No name 2" exhaust cat back to a Stock Muffler
- 99-00 Si Full interior
I have 1 extra wheel has a very slight bend but still holds air will be included, tire on the extra rim is no good
Civic also has a full working alarm! 1 regular remote 1 LCD remote included!
Interior Condition
Interior is in really good shape, Interior is not the stock EX interior this has the 99-00 Civic Si interior.
99-00 Si Seats Front & Back no rips or tears
99-00 Si Leather Wrapped Steering wheel
99-00 Si Cluster with 56k on the cluster
Carpet is good just a few dirt stains that will come out with some scrubbing, no visible tears that i can see, has no name black floor mats that are almost new. Headliner looks ok, some sagging spots but not bad. Trim around sunroof needs to be put on correctly is there just not put on right. Visors are ok, the edges of them are deteriorating but are still there not bad looking just want to describe everything in detail. Door panels are all nice and tight, stock tweeters are there. Rear panels are all there no damage. Rear deck lid has a crack dont know if its due to the sun but it has a crack (pictured)
All the windows go up and down, sunroof works everything works. Radio is a kenwood cd player older model but it has a radio might want to upgrade that since most people use there ipods or phones to play music
Engine & Parts Included
As stated this car does not come with a motor but does include the b16 trans and other parts, all you need is a motor pretty much and maybe misc bolts here and there. I have all the bolts in a zip lock bag, all the bolts i took off i put them in the bag! All axels, shift linkage, clutch master cylinder, wire harness, radiator, a/c compressor, fans still on the car. transmission is off the car! Includes stock B series flywheel needs to be resurfaced in order to be used. Excedy stage 1 clutch with pressure plate and alignment tool included. 4-1 header has 02 sensor. Catalytic converter was removed and replaced with a cat delete resonator i do not have the catalytic converter.
OBD 1 p30 Chipped ECU with jumper, had a B20b running off the ECU and it ran perfect all you have to do is swap the manifold with a OBD 2 LS intake and sensors and your good. This ECU does not require you to change the oil pump to put the crank sensor since OBD 1 motors do not have crank sensors. I will also include a b16a2 OBD 2 intake manifold, this manfold does make a bit more power then the LS one and looks alot nicer. You will have to modify the manifold to fit a b20 if that is what you plan on running on this car.
A/C compressor and A/C condensor still have freon in them, if you bolt it up your A/C will work! Powersteering pump is also there may need a bracket not sure if I have it but im about 75% sure I do somewhere.
Does include a battery as well
Stock Si engine mounts are installed the car ready for the swap!
Axels are 99-00 Si axels
Old Jul 7, 2013 | 01:48 PM
AL1222's Avatar
Default Re: F/S F/T CIVIC EK SHELL W/B16 TRANS NEEDS ENGINE! HAS MODS! REGISTRATION CURRENT!
Bump
Old Jul 8, 2013 | 10:27 PM
AL1222's Avatar
Old Jul 8, 2013 | 10:30 PM
kingofbattle909's Avatar
holy giant pictures batnam!
Old Jul 9, 2013 | 08:44 PM
AL1222's Avatar
Old Jul 14, 2013 | 04:40 PM
AL1222's Avatar
UP
apm
Northwest (Sales)
Sep 14, 2011 07:34 PM
ACinema
Jul 19, 2011 01:05 PM
CubbyChowder
Sep 9, 2010 01:46 PM
nyce1
Sep 27, 2006 12:04 PM
makinasvp
Jun 3, 2004 09:46 AM
