Jaydec11 build thread h2b content
Hi I'm Jason I been building my eh3 hatchback for about 2 yrs now ...everything has been done from the ground up I mean everything lol take a look at my piks ill be updating it once I get new piks as oh rite now I'm wait in to retune it this month tryin to have it ready for Honda day at englishtown
H22a block*
89mm bore
12.1.1 cp pistons
Eagle rods
Arp rod bolts
Balanced shafts eliminated
Sleeved block
New oil pump
New water pump
New timing belt
Arp head studs
Cosmetic 89mm head gasket
H22a head
Super tech valve train
Over sized valves
Cut valve guides
New seals
Exhaust n intake ported
Brian crower stage 3 all motor cams
Adjustable cam gears
Transmission
B16/LSD no grinds no pop outs
Comes with brand new Evo kit with mounts
Complete and clean obd 1 harness h32 ready
Hondata s300 already dyno tuned for this set up
Also comes the the half shaft and axels and starter
Pistons
LSD
Injectors cam gears n cams
Head studs
Itbs
Evo kit w/ mounts
Balance shaft removal kit
Block with kit
Itbs on my head lol
B16 trans
This was wen I dunno tuned her for the first time thanks to CLM MOTORSPORTS
Since that tune I changed a couple of things like intake throttle body injectors
Here are the headers I am using now LOGIC TRI Y H2B HEADERS
How she sits now
A lil pik next to a rhd original sir
This happen back in October thanks to hurricane sandy smh
Here's a lil 15 second bid of her on with the new setup
H22a block*
89mm bore
12.1.1 cp pistons
Eagle rods
Arp rod bolts
Sleeved block
New oil pump
New water pump
New timing belt
Arp head studs
H22a head
Over sized valves
Cut valve guides
New seals
Transmission
Pistons
LSD
Head studs
Itbs
Evo kit w/ mounts
Block with kit
Itbs on my head lol
B16 trans
How she sits now
WTF are you bumping your own thread for? This isn't a build thread. It's a photo album. Check the forum rules as to what a build thread actually consists of.
Ohh I'm sorry I didn't post the prices nor were I got my wrk done ill make sure I fix that juss for u.....n I felt like bumpin my own thread
If you loved me, you'd all sell me your magic cards to me today
Try the appearance thread, also proper grammar and spelling would help understand what you are talking about.
O RLY
Mar 9, 2006 07:17 PM
