Prelude H22 and Civic Tons of cheap PARTS!!!
97-01 Prelude H22a4 Vtec ECU - $40
MFactory Oil Cap - $50
Exhaust Hangers - $30
Sustec 97-01 Prelude Rear Lower Control Arm Brace - $75
H23 Blue Top Valve Cover (Fits H22's as well) - $60
H23/H22 Steel Oil Pan and Baffle Plate - $40
Two H22/H23 Timing Belts - First picture is the one that's brand new, the second one has been on my engine to degree and was ran for 1 hour. $50 ror brand new, $40 for used for a hour
H22/H23 Parts
- Block Heater - $40
- O2 Sensor $20
- Water Pipe - $20
- Oil Pressure Sensor $15
- Oil Cooler - $50
- Fast Idle Air Control Valve - $40
- H23/H22 Balance Shaft Bearings (New, just dirty. I had Balance Shaft Removed on my last engine and these bearings came with the kit) - $30 for everything you see
H22 Oil Pick Up - $10
Balance Shaft Removal Plugs for Delete on Oil Pump - $10
H22 Header Gaskets - $5
1 Bar MAF Sensor - $30
OBD2 to OBD1 Distributor Jumper Harness for a civic (so you can run a OBD1 distributor with your obd2 civic) - $60
H22 Aluminum Oil Pan and Baffle Plate (I have two of these) - $40
H23 vtec distributor and H22a4 distributor (both OBD2) - $40 each
Water Temp Sensor (Universal) - $10
H22/H23 Parts
- O2 Sensor $20
- Water Pipe - $20
- Oil Cooler - $50
oomicha3loo
Jul 13, 2011 09:34 AM
