Few Questions, Doood welcome!
Old Jul 5, 2013 | 08:29 PM
Orangevirus1's Avatar
Default Few Questions, Doood welcome!
What is a known safe HP/TQ number on Stock sleeves for a b18? no block guard, nothing.
What kind of spool up range would I be looking at if I run a Borg Warner S256SX with a 1.00 AR T3 twin scroll hot side?
( around 60+lb/min ) I want to run it at around 2 / 2.5 bar. E85 of course
on my 2.0 engine I was seeing 5k+ full spools. ( althought it was a 6 cylinder 2.0 with 7.8:1 Compression, I'm running 10:1 on the B18)
Is there any difference ( pin wise ) between a OBD1 PR4 ecu and OBD1 P75? ( or whatever other LS OBD1 ecu )
When does the stock intake manifold / throttlebody become a restriction?
What head work needs to be done to rev a LS head to at least 8000? I'd prefer 8500 to get maximum potential out of the BW S256SX
Old Jul 5, 2013 | 09:00 PM
doood's Avatar
been there done that
Default Re: Few Questions, Doood welcome!
you should try 18:1 compression custom pistons
Old Jul 5, 2013 | 09:03 PM
Dang I think I'm being E-Stalked
Old Jul 6, 2013 | 12:45 AM
doood's Avatar
you put my name in the thread title you ******* moron
909ej
Dec 31, 2010 09:11 PM
lilxchris
Mar 20, 2009 08:00 AM
Tinker219
Mar 8, 2003 04:32 PM
