Need 99 civic dx engine wiring harness diagram/wire colors for plugs.
The harness I have is all unwrapped and I'm trying to tuck it on my swap that I have on an engine stand. I have like half of it connected and the other half I need to figure out what wire colors go to what plugs since some of them are the same.
I've seen here before but can't find it atm a thread where every plug was shown pictured with wire descriptions. Can anyone help?
It's a single cam non vtec wiring harness with vtec added. It's obd2b
Also I need to convert the dizzy plug to a b series(obd2a basically) plug but where I see that the ign input wire slot on the obd2a plug is bigger than the one on obd2b. How can I fix that?
I already have map/tps/injectors/iat/iac/oil pressure/thermostat ground/fan switch all done
Ok now what about the dizzy plugs? Going from obd2b plug to obd2a big plug. I can depin all the wires but what do I do with the 1 fat wire slot since my small 8 pin plug on my harness is a smaller wire?
Going from the 3rd plug down to the 4th plug on the page but #9 is what I'm talking about. On the harness, the wire is smaller. Do I just cut and splice it to the bigger wire?
