How to install a/c in a 91 civic with a d16z6 swap?
Old Jul 5, 2013 | 07:16 AM
GRIMRemembeR's Avatar
Default How to install a/c in a 91 civic with a d16z6 swap?
I have a 91 civic with a d16z6 swap and the guy who had it before removed all the a/c components. The engine came out of a 95 civic so would i need all the a/c components from that car? Also what all do i need? Im sure there are little things im not even realizing i need.
Old Jul 5, 2013 | 09:09 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: How to install a/c in a 91 civic with a d16z6 swap?
I've never done it...but because it's a d series block, i would imagine you could just reuse all of the original parts from your 91 civic. If you are missing parts, you will have to track down a complete inventory of what is needed.
Old Jul 5, 2013 | 03:30 PM
jonGSR's Avatar
Evaporator core, expansion valve, receiver/drier, compressor, condenser, ac fan, bracket with pulley and belt, all appropriate lines, r134 conversion adapter for both the high and low side so you can properly vacuum and recharge the system.
You may want to have a shop do the vacuuming and charging for you though.
Old Jul 6, 2013 | 08:22 PM
Thank you. I wouldnt care so much but its summer in florida so its kinda hot atm
boomsplat
Aug 28, 2013 09:16 PM
1kleenef
Jul 29, 2007 05:44 AM
VtecHusker
Mar 23, 2007 03:59 AM
psychadelicfreedom
Jun 26, 2005 02:58 PM
