Oil in head bolt hole?
Old Jul 4, 2013 | 09:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Oil in head bolt hole?
Pulled my B18C1 head to change the head gasket. Found oil on the threads of one of the head bolts, the center bolt on the intake side. There's also oil inside the bolt hole. Should I be concerned about that? Or could that be a product of the head gasket being blown? I did have coolant getting into the cylinders, and also coolant mixing with oil.
Old Jul 4, 2013 | 11:43 PM
Runnerdown's Avatar
Default Re: Oil in head bolt hole?
If you look inside that hole in the head, you will see that its exposed to the oil feed holes drilled through. On the intake side of the head you will see the allen plug where the passage is. it lines up with that and goes straight through.
So in other words, perfectly normal.
Old Jul 5, 2013 | 06:11 AM
Community Builder
Alright cool, thanks.
drsab2000
Mar 5, 2015 08:15 AM
Sr420Det
Apr 16, 2011 02:55 PM
Ryan559
Dec 22, 2010 09:43 PM
yamahar12009
Mar 5, 2009 07:30 AM
strsi
Apr 6, 2005 05:28 PM
